Hi, I’m trying to get to the bottom of the Audio setup in my T6 with discovery media headinit.
Starting at the back of the van I have some Hifi speaker leads that run off under the trim and work, I’ve plugged speakers in and they work. I’ve also got in the middle of the van a set of leads for a sub/amp, 2 phono and power. I assumed this was a sub connection rather than rear speakers as the rear speaker wires don’t then join back up with this.
Looking at the back of the head unit I’ve got the attached, now I assume it’s a lead to RCA converter box, does anyone know what make? It appears to have some adjustment on it? The other confusing thing, is whether this is coming from the rear speaker feed on the head unit (all pins are used on tbe connector into the head unit) or whether it’s doing something to create a low pass channel? For sub? It’s connecting into the grey/black wires and then into the vehicle section of wiring only 4 connections (the front speakers) connect in.
So I would appreciate best guesses at how it’s been configured?
Do you think the rear speaker leads I have, have just been spliced into the factory wiring loom with the fronts? Ie super dodgy way to do it, and then the previous owner had a beefy set of rear speakers running off the amp?
I’ve attached some pictures. I’ve been looking around various upgrade threads so have an idea how people typical add the rear speaker wires but haven’t seen this loom before
