17” tyre recommendations
The higher load rating will be able to resist overheating at higher loads than required. This inevitably creates a stiffer sidewall and with that, a firmer ride.
However, higher rated tyres tend to be used on heavier vehicles at higher pressures. Used on a lighter vehicle, at lower pressures it's unlikely to make much of a difference and if it does, I've yet to see an exact figure. What I mean by that is that a tyre designed to carry 10% more load won't feel 10% firmer.
Going to a higher rated tyre will give you many more options. If you go for a larger tyre, something like a 235/65/17 for example, you can run them at slightly lower pressure than the standard sizes. This would probably cancel out any perceived increase in stiffness from a higher load rating.
Thanks very much :)
Tyre pressure recommendations?
I'm just getting some BFG All Terrain's fitted to replace my worn-out Cooper Discoverers.
They're both the same size (245/65/R17) but as non-standard tyres I've never known the correct pressure.
I'm setting off tomorrow to drive fully-loaded to Italy, so want to be sure I've got it right!
Any suggestions?
There should be a sticker for tyre pressures for your van visible when you open your driver's door.
There is but it won't cover the 245/65 tyre size.
This is a good guide:
I read on a recent post on a FB page way to set pressures is as follow:
- set pressure in region you think is ok (say 45psi)
- drive an hour
- check pressures warm
- if pressure has only increased 4psi you set correctly
- if gone up more than 4psi you set too low, let tyres cool and increase accordingly by the difference
- if gone up less than 4psi you set too high, let tyres cool and increase accordingly by the difference
Ill be interested to hear you lots views on this as lots of experience and valued opinons!
I have similar size Falken Wildpeaks just added. I had set at 46psi and after an hour drving they were 49psi so based on above I will set at 45pis.
Now I have a fully loaded van for a long trip so I will do the journey again and see. I suspect I will need more pressure for the extra weight which ties in with the sticker in the door on my shuttle.
I'm running 45psi on 245/64R17 Falken Wildpeak at3wa tyres.
Any suggestions?
How did you get on with the BFG (245/65/R17) tyres - where they on a T6? Sorry if I missed that bit. Thanks
Our tyre man has said "There isn’t a great deal of choice in the 104/102 and as the 98H or V are insufficient then it might be worth looking at a higher rated tyre like the 109/107. We can get….. Continental VC200 £158.60 + vat per tyre, Goodyear EGrip Cargo 2 £157.20 + vat per tyre, Avon AV12 £137.60 + vat per tyre, Uniroyal Rainmax 5 £138.50 + vat per tyre. If you wanted an ALL SEASON tyre we can get…. Uniroyal £156.55 + vat per tyre, Goodyear Vector 4 Season Cargo £193.42 + vat per tyre. Alternatively Goodyear Vector 4 Seasons Cargo in a 104/102H at £154.00 + vat per tyre or I can also get a Kumho in a 104/102T at £108.00 + vat per tyre"
Trying to get the best solution for the least cost - any advice please?
Evening - what you decide to do in the end?
I run a T32 Kombi with 215/60 R17 107/109T and they're reaching the end of their life. The van isn't loaded very often and I find it a harsh (and noisy) ride. Just looking at tyre options, along with advice.
Any suggestions?
Find a tyre comparison site there are few, then enter all the standard manufacturers tyre details in the first table for comparison including recommended pressure, then in the cosponsoring table put in all the known details of a tyre that you are considering. The comparator will highlight any differences in tyre size, speedometer readings at certain speeds percentage increase of speed and so on. Also a new tyre pressure recommendation for the new tyre will also be available.
I’ve got my wildpeaks at 36psi. It’s very comfy. Should I be at 45? I know others are running them in the 38psi region.
Depends on your van, weight etc. I see you have a camper, do you know what it weighs?
Mine is a Caravelle which as standard is 2400kg unladen, over removed the 100kg rear bench but added back in probably 200kg of kitchen, fridge, roof rack, bed.... And that's before it's packed up with a bike, water, and luggage etc for a trip!!
I am thinking of installing Bridgestone Dueler A/T 002 225/60 R17 103H 4-season AT tyres on the 7J 17" wheels of our 4-motion T6.1 California.
What is your opinion, and what would be the best tyre pressure since these are as non-standard tyres?
I've just put these on my Devonports for winter, not sure about the pressures, think the garage put too much in as they feel less comfortable than my 20s do normally :D
Hi all, I am after some advice on what size of 17" tyre to run.
I have a 2019 T6 fitted out as a camper which currently has the factory 16" steel rims with 215/65R16C Goodyear Marathons. It is a two wheel drive TDI340.
I have been able to pick up a set of Amarok Aldo 17" Alloy wheels (17"x8J) which I understand are a direct fit with an offset of ET49
They currently have worn out 245/65R17s from the Amarok which are too big in circumference (10% bigger) so I want to buy a new set to suit the van before I put them on.
It mainly does highway miles but of course needs to go up dirt roads to get to camping grounds here in Australia, nothing too serious but the reason I didn't want to go bigger than a 17" wheel.
The sizes I am considering are;
235/55R17 - The Kumho Ecsta HS51 or Hankook RA23 look to be a good option here? This is the standard VW size for 17" I think and same circumference as current 16"
235/60R17 - I can get Pirelli Scorpion Verde All Season in this size with correct weight rating - about 3% bigger
215/60R17 - have not investigated what tyre is available in this.
What do people run and what is their impression of comfort vs grip vs offroad safety. The van currently rolls a bit when cornering at low speed, so hoping the new tyres might reduce that a bit.
I didn't like the body roll, so I had uprated anti roll bars fitted. That meant I got a smoother ride tan low profile tyres, and no body roll
