I want to change my air filter. The part number is 7EO.129.620
Measured it . L=310mm w=190mm
As regards height do I I have got 65mm approx from the bottom of the fiter up to the rubber rim
Where would I get the genuine part from or would euro carparts Bosch or Mahle filter do the job?
Living...
I have a 2016 T6 FWD Euro 5 140 HP van.
My air filter had done about 44000kms, many of those on dusty roads. It had been replaced at 30,000km by VW. So van has done about 74000km now.
My engine appeared to be working fine but I thought because of hardish use [Dusty roads] , I would inspect...
I can't help but notice that my T6.1 Shuttle is totally useless at filtering out outside pollution, smell and smoke compared to my wife's T6 California Ocean. Is there any reason for this and is there some way I can make my T6.1 shuttle better at filtering out outside crap?
Evening peeps....
I have noticed that the side retainer, on the lower left side of the air filter box is missing. Broken off it looks like. This retainer, slides into the the wing, just to give some support to hold the lower section of the air filer box in place. Unlike mine wobbles around like...
Anyone opened up the airbox under the filter to see like a plastic ‘snow grate’ type insert in?
anyone removed this like they do in the golf gti/R and fit a free flowing filter?
Wondering if there’s any dyno with and without kinda thing.
Service Parts List - What Goes Where -
Here is a Basic list for all Parts required for Servicing which will be updated moving forwards:
Brakes:
Pads:
308mm F Pagid Brake Pad (Front Axle) Product Code: 101441298
340mm F Pagid Pagid Brake Pad (Front Axle)Product Code: 101441868
340mm F Brembo...
