Windscreen washer low pressure
Foofighter25
Hello all
I noticed my windscreen washer pressure was low. Done some investigating and realised that the pipe located at the NS bonnet hinge that connects to the washer jets had split. Apparently a common problem. Managed to repair the pipe but still have low pressure at the jets. I've had the jets out and blown through, disconnected pipe at pump and blown/sucked through with a large syringe. The pump seems to be working fine as it's making the usual noise. I'm stumped. Any ideas people?
New pipe is probably your best best over a repaired one. Should be less than a tenner. A perished pipe that has been repaired is still perished, I'd imagine it's brittle and shot regardless of the repaired split. Hope you get it sorted buddy - awesome screen name btw
