Whine from front
T62019
T6 4Motion DSG (2019)
I'm chasing a whining/howling noise that starts at around 80 km/h and seems to come from the front of the vehicle. The noise remains unchanged if I shift from D to N while driving.
About a year ago, the right front driveshaft was replaced because the inner splines were worn. That fixed the original issue. At the same time, the transfer case oil was changed and there was a small amount of metal debris found in the old oil, although I'm not sure if that's related to the current noise.
Wheel bearings seem fine, and the front shock absorbers were recently replaced, but the noise was present before that work.
The driveshaft center bearing support has some cracks in the rubber, ordered a new part but haven't got to replacing it. Although I dont think that could make this noise unless the support bearing is also faulty?
Engine and gearbox mounts have been replaced but noise was present before.
Has anyone experienced a similar whine/howl on a T6 4Motion? Any ideas on what to check next?
I would go back and check the same oil again. Metallic contamination will have increased clearances and destroyed surface finish and hardness. Once this process starts it unstoppable and will continue until complete failure. Earlier intervention may reduce the parts bill, changing the oil and hoping it gets better won’t.
Actually the transfer case oil has been replaced a few times already, for maintenance sake. It has always had a bit of metal but doesn't seem to be broken. When last checked, it seemed ok.
The noise is a bit of a mix of wheel bearing noise and whining noise. Could it be coming from the dmf as it's making a slight noise also?
Found the issue. A failing power steering pump. Weirdly it wouldn't make a noise when turning stationary, but give it a few revs and the whining would start.
