2018 t6 4motion manual gearbox oil fill hole and volume
craighy
Hi all
As per title I have just fully rebuilt my t6 4motion manual 150bhp after engine faulure and all is good except for a horrible grinding noise on second gear
I have drained and refilled the front transfer box which took around 0.8l liters of genuine vw oil supplied specifically for the it by vw parts
I dont remember draining the gearbox when I stripped everything but I am planning to drian and refill just to rule it out as the cause of the noise
Can anyone help with location of fill hole on the manual 4motion t6 gearbox as it does not seem to have the same large Allan head plug that the fwd ones do in images found online
Any help appreciated
There is some mention of later vans not having a filling plug, not sure if this applies to yours. Part of VWs low cost (no) service regime.
Have a Search, some have changed the oil through a gearbox port after removing the neutral switch, far from ideal.
Thanks for that I'll have a search
Yes that's definitely not ideal especially when I dont know how far from full it is 🤨
The only way to know much oil it has is to drain and measure it. You never do that before you identify a means of filling, oil spec and quantity required. Don’t rely on AI for the details
I had this challenge, 19 plate 4mo 6 speed, has a drain plug but no filler/level plug
Believe it should be 2.7l
Draining the box I had 2.4l come out
Refilled through the reverse light switch
Just did a gearbox oil change to a MY19 T6 4motion 6-spd(0A5, SAW). The fill plug was on top of the diff facing the bulkhead. This was propably the first one for me when fill plug isn't on the fill quantity level, but above it.
Fill plug with washer N 911 805 01
Drained oil ~2,4 l
Filled oil per service manual 2,7 l 75W GL-4
