Yup. Depending on your roof, possible. What type of roof? Mines a Skyline Aurora.@RunDSG Do you mean running it from the gromit in the tailgate all the way to the cab headliner without actually having access to it? I've read that the run from the gromit just into the back of the van is bad enough!
If I recall correctly…
- along windscreen to near side A pillar
- above headliner to B pillar
- I don’t know what to call this bit, but inside the ridge all the way to the back. I popped out the round lights to help me move it along
- at the back corner it was tricky finding the grommet behind my rear cupboard but I got there
- then through the hose into the tailgate
- and I brought it back out behind the panel at the base of my rear window
Hardest bit was the tailgate. I used zip ties to find the wire and feed it through. Admitted a job I don’t want to do again but really glad I did it.
I would advise some research into the rear camera. Is it future proof? If you later upgrade your dash cam, can you use the same rear camera?
I THINK my Nextbase camera uses mini-HDMI and I’m hoping this allows that flexibility in the future. I haven’t had a chance to test.
And this requires so much effort, I’d buy the best camera I can afford to avoid the risk that it’s just sh*t in the end anyways.
I don’t know if this is helpful. I probably have some photos…
