Thank you for the responses and guidance. I have a 6mm fused cable, but I will get a larger cable if necessary.
It will be to run to a 12 way fuse box which will supply power for 8 led lights, 12v plug, 2 usb sockets, fridge, TV and possibly water pump.
When I figured out my (fairly normal) current requirements, I found I had to massively oversize the cables to keep volt drop down. So at least in my van, 'draw' (or current/Amps) is not the deciding consideration at all.Same here, 10mm fused.
Ideally you need to know what your planning to run from the fuse box and then figure out the draw and add it all up, then bank on 20-25% extra capacity.
Thats my route .
Not at all, my reply was a little too generic.When I figured out my (fairly normal) current requirements, I found I had to massively oversize the cables to keep volt drop down. So at least in my van, 'draw' (or current/Amps) is not the deciding consideration at all.
For instance, Fridge, Heater, lights, water pump combined will use around 12A. 1.0mm cable can handle this, but volt drop over 6m will be 2.8V, obviously unacceptable. 2.5mm cable can carry twice the 'draw', but still volt drop is a nasty 1.2V. To keep volt drop under 0.5V it turns out 10mm is needed (so I used 16mm!)
1. Size the cable for the volt drop
2. Size the fuse for the load
3. Check the cable is big enough for the fuse (it most likely will be)
I hope I don't sound like I'm picking at your method, just trying to help!
I fused it at 30A. If I remember correctly, I couldn't get a smaller MIDI fuse, or I would have used a 20A.Not at all, my reply was a little too generic.
My point was that you need to know why your hooking up to the fuse box to really determine your cable size.
Out of interest what size fuse did you use for the 16mm cable?
Hi Pete, thanks for the quick reply. It will just be powering the fridge for now but was planning on adding a heater in the near future.
When you're working out voltage drop, then you need to add the length of both positive and negative cables - If you think you need to uprate the positive cable to 6mm, then you almost certainly need to uprate the negative as well. - But if the negative is routed to the leisure battery via the chassis and good connections, then hopefully the voltage drop through the chassis section is low, its just fridge to chassis cable and chassis to Leisure battery cable you need to consider.Hi all
Can I just check if you also need a bigger cable for the negative on a fridge. I am wiring my dometic cr50 straight to leisure battery as it’s currently to a pms3 and have some 6mm wire for the positive. There is the existing 4mm negative/ground wire which I am thinking of using or should I replace it with 6mm.
Thanks in advance.
