Perfect colour match!
A new fence?
Wasn’t planned either. Thought it might work, but pleased with how well it matches.Perfect colour match!
The ferry is quite a bit cheaper then le shuttle. I go over to france a couple of times a year fishing, but always opt for le shuttle for speed.Was it cheaper than the tunnel John ?
Interested why you chose the boat rather than the train?
The tunnel gives you 1 hour leeway and if you're later than this you have to buy a new ticket, the ferry as 4 hours leeway and £60 if late.Was it cheaper than the tunnel John ?
A wise move. Next year try the Buzzweld stuff. Much less expensive, and having used both I believe its a better product.And a 500ml top up bottle of Lanoguard to put another coat on underneath before the salt starts getting spread on the roads.
So... I've sat with all the gear in shed for over a year or 2. Do you need to be careful where spraying etc? Or is it acceptable just to spray underneath / wheel arches etc? Afraid I may be late as weather Def changed here.... One of my Lazer light bracket fixings has corroded so need to fix / repair that also.A wise move. Next year try the Buzzweld stuff. Much less expensive, and having used both I believe its a better product.
