cottya
I am currently experiencing a non start issue on my CXEB engine.
It blew one of the turbos in February, I pulled the engine and stripped it completely. I had the turbo re built and had the cylinders relined at the same time. With the re build I replaced all the necessary seals/gaskets lapped in the valves etc.
It's now all back together, but won't fire up. It is really close but doesn't seem to catch and run.
There are no fault codes!
What I have done so far:
Quadruple checked the timing and and the crank timing ring.( yep I took the engine back out just to be sure when it would t fire up). Used VCDS to have a look at some of the measuring values but I am not very good with it so stabbing in the dark really.
Any direction or guidance would be really appreciated.
