KiwiT6CFCA
Hi All,
Greetings to you all!
I have had ongoing problems on my T6 Multivan CFCA. When I purchased this van from a dealer, it was drinking lots of oil. It was found to be the EGR issue that we all now know about and since then, my engine was removed, reconditioned (by an engine reconditioner, as a long block - not Volkswagen) and reinstalled by my local mechanic.
I drove the van and the turbo failed while out of town - this should have been done during the recondition but wasn't.
A new turbo was fitted and the van seemed to be running fine.
On a long drive, the engine pressure alarm came on. I pulled over - checked the oil, it was fine. Drove off and it was cleared.
Taking the van out on 10km + drives the alarm would return.
I took the van into our local Volkswagen dealership.
They replaced the oil level switch.
This was a waste of time as I told them it was pressure related not level related. The low oil level alarm issue kept coming up usually when the engine was hot and the engine RPM's were low.
The re-booked me in to have the oil pump replaced.
They replaced this.
During the next 8000kms, i continue to get the low oil pressure alarm. If I shift the DSG to manual and drop down a gear, the oil pressure boosts and the alarm goes away.
I rebooked the van in with our local Volkswagen again.
They have called me today to say that they cannot find the cause. They don't think its the pump as they changed it 8000kms ago. After the service manager consulted with 2 x Volkswagen Trained Master Mechanics, they tell me that my best option is to get a new engine!
My engine now has approximately 15,000kms on a recondition and this is what I am presented with...
I know there are some really talented T6 owners on this forum.
Does this sound right to you all?
When I get the report, I will post it here but surely in the times we live in, oil pressure can be tested in a way where faults can be found and rectified.
I cannot afford a new - or good 2nd hand engine. Even with my 3rd party warranty as this only covers up to NZ$3700.
Does anyone have any suggestions?
Thank you very much for reading this far!
Karl
2016 180 Bi turbo CFCA engine failure is the EGR valve corrosion the cause of the scored and worn out bores
Hi Loz, thank you for that. I've decided to have the engine rebuilt. My indi gave me a price for the engine to be removed and all ancillaries taken off and the put back on and engine put back in. A company near whare I live will rebuild the engine, just waiting for a price, they've got an...
www.t6forum.com
They replaced this.
Karl
