Vw Scirocco 18 Wheels (57.1mm) On My T6 (65.1mm): Any Solution ?
P0L0
Hi guys !
I'm looking for wheels for my t6.
I found a set of four wheels from a Scirocco in my area.
The probleme is: All T6s have a centre bore of 65.1mm, and these wheels are in 57.1mm.
In the opposite way (65.1 wheels on 57.1mm vehicle), we can use spigot rings.
But in that case, is there any solution ? I was looking on ebay to find spacers that could be a solution, but that remainq unsuccessfull...
Standard 16" steels have ET51
those wheels are ET41, so the side of the rim 1cm more outside.
With 20mm spacers, would it be ok ? I mean: do the wheel will hit the fender with them ?
thanks a lot
No, not even close
Car wheels are never rated enough for vans
Check your sticker at the back of the engine bay on the bulkhead it will give you your max axle weights and they will be around 1700-1800 kgs
