Victron Smart Charger
CALLAKN
Electrician / Linesman
T6 Legend
Just a quick one lads,
it’s all fitted and seems to be working fine! Just wanted to check this is all normal stuff, when I first plugged it into 240v it was reading this -
And now it’s been on charge for a few hours it’s reading this -
95E7F5B3-14BC-4C38-A40F-8D8B997D1F57.png 95E7F5B3-14BC-4C38-A40F-8D8B997D1F57.png
that looks perfect for a SLA/AGM battery, (thats a great charger, I've got the 15A version)
you need to change the mode only if you went Lithium . . .
and as Pete says . . . Update the firmware.
is it a perm fit via EHU or just plugged in to boost the battery?
got some more pics of the install/battery/van/etc
And I updated firmware straight away when it gave me option, why, is it showing theres an update?
there may be more that the one update . . . .
ie first update is for bluetooth module,
second update is for the charger firmware,
or update failed and needs redoing.
Does anyone know how much ventilation these units need?
Also can you earth the unit via the chassis or does the ground need to run direct to the battery - post?
