Thanks for the insights appreciatedI've got both...
And both are very good..
But use different tech inside.
Victron is bigger and heavier as they use transformers.
Renogy use MOSFETs, so smaller and lighter.
Both have a remote on/off option.
But only the Victron has the remote app monitoring via the Bluetooth ve direct port.
The Renogy is cheaper.
The Victron is more expensive, but has a proven quality history.
Fwiw....
I've had issues with some inverters moaning and showing errors with surge blips.... And shutting down. ( Eg 800w load on a 1000w inverter, but micro blips over the 1k, but under the total surge rating... A lot of inverters shut down)
The Renogy sailed through the testing and sucked up any small blips.
[Guide] 12v/240v Power Inverters -- How I Done It --
12v/240v Power Inverters -- How I Done It -- Place Holder - current work in progress. -- coming soon the other inverters i have that are worth looking into are: All @Dellmassive tested and approved. Victron 375w, 800w, 1200w COTEK 250w, 700w, 1000w, 1500w Renogy 100w,2000w Vict. 12/375...www.t6forum.com
Thanks, i'll pickup a Victron 1200 then, Is it worth getting the bluetooth dongle?out of the two above inverters i would more more inclined to say the Victron will be better as it can surge + 200%..
i have the VE direct port BT adapter. . .
eg:
View attachment 171106View attachment 171108View attachment 171107
Thanks @Dellmassive, champion!then download. . .
VictronConnect
its loaded with demo files to play with. . .
Here is the MW - 800wstartup surge could be double.
@czmate1999 runs a small microwave.
i think runs twin 100ah lithiums and a 2000w inverter.
@czmate1999 - whats size inverter is yours?
So on max settings on the microwave state 700w : this oneThat prob wont be enough for your microwave, as a general rule you double the microwave wattage to get your required invertor size
I think the average microwave runs at about 1.8 times the microwave power so yours will likely be 700*1.8 so around 1260 so defo need to double check the specs/ratings and prob go upto a 1.5kw invertor
