Anyone have or considered fitting a Victron MPPT under the bonnet? specifically in the battery compartment which in my case is a T6 Caravelle. I’ve done some research, a thread on the Victron community forum states they don’t recommend it due to heat and its IP44 rating but I would argue it can get equally hot inside the van when left with doors and windows closed up. The battery compartment is dry, I already have a mains consumer unit fitted there although that is IP65.
I only use portable solar panels so the controller will not be actively charging and when it is I could leave the bonnet propped up. There is no more room under either of the seats in my Caravelle and MPPT controllers are recommended to be installed as close to the battery as possible. In my case I want to use it to charge the Starter battery. I’d just use an Anderson connector to plug in the Portable panel when require, I currently do this now with the MPPT input on the CTEK.
I could fit a 12v cooling fan and connect it to the load output of the Victron MPPT, have it active only when the battery voltage is at a level for charging. I’m going to test it out with thermometers etc. but wondered if anyone had any ideas?
cheers,
Nick
cheers,
Nick
