hi, I have fitted LED Driving light bulbs to my T6, does anybody know the location of the code to disable the warning for this using VCDS please
Did you check if @andys post at VCDS codes list does the trick?Hi, in VCDS does anybody know how to disable the bulb warning as fitted led and it now stays on, so would just like to disable if possible please?
Did not work for me.Did you check if @andys post at VCDS codes list does the trick?
Central electrics control unit:
Byte 16 Bit 6 Lamp Diagnostics for (Separate) Daytime Running Lights (DRL) active
Thanks Paul, I think you are right, I might stick originals back soon. Have you any idea of any good upgrade bulbs for the driving lights, I seen the Philips 130, but I haven’t had good reports on the difference being that great, I use to put in 100w bulbs on older cars, but worry if they might be too hot for the plastics lens, what do you think?I have been doing a bit of digging into turning off lamp warnings and I’m not sure it’s possible
You can disable the setting in VCDS and this turns off the’cold’ or ‘startup’ lamp check but if my understanding is correct it implies you cannot turn off the ‘hot’ or the ‘running’ lamp check which occurs when you are driving or when the lamp is used (turned on/off)
I haven’t confirmed this yet but know it was true on other vehicles pre MQB platform so I am assuming it’s carried over
The perils of an uneducated marketing dept. They were at one point advertising these as "150% brighter", which would be two and a half times the light output!I used Phillips Racing 150% (100% being standard bulb so only 50% brighter) which make an improvement. Also had dip beam position adjusted as it was too far to the left.
Yes, it would, can you suggest some please?Wouldn't it be better to find LED DRL bulbs that don't trigger the warnings rather than disable them? Mine work fine with no errors and I'd rather have the warnings working.
These are the ones I have. No errors and no signs of heat damage CICMOD 2pcs 1000 lumens 1156 BA15S P21W 4014 45pcs Chipsets LED Bulbs For Turn Signal Backup Reverse Lights, Xenon White 6000K https://www.amazon.co.uk/dp/B01LCN5Z0I/ref=cm_sw_r_cp_api_rsMPAb8JVS2GZYes, it would, can you suggest some please?
Thanks, i have orders some. Now any idea of any bulbs for the headlights, LED preffered?These are the ones I have. No errors and no signs of heat damage CICMOD 2pcs 1000 lumens 1156 BA15S P21W 4014 45pcs Chipsets LED Bulbs For Turn Signal Backup Reverse Lights, Xenon White 6000K https://www.amazon.co.uk/dp/B01LCN5Z0I/ref=cm_sw_r_cp_api_rsMPAb8JVS2GZ
