VCDS And Carista Fault Codes
Loz
Moderator
I noticed with Carista that it resorts to google to search the fault codes and ironically we seem to get most of the search results pointing at this forum but the codes are just appearing in conversations mentioning those codes so I thought we should create a topic and list the common ones as they come up and collate information about the code with any details we can crib together.
I’ll make a start with a couple and others can add theirs and see how it goes.
Address 01: Engine
17668 - Diesel Particulate Filter; Differential Pressure Sensor
P2456 00 [100]
Or
32855 - Differential Pressure Sensor for DPF
P154B 00 [175] - Faulty
MiL light on
Notes:
Faulty DPF pressure sensor causes an incorrect ash reading that prevents regeneration from happening. This will eventually lead to limp mode.
Replace and adapt a new sensor asap.
Address 01: Engine
15560 - EGR Sensor 1
P046C 00 [039] - Implausible Signal
This is a software issue in the ECU not a fault with the EGR the ecu has received a value it was not expecting VW advise to ignore/clear. May get fixed with a future software update.
Address 02: Auto Trans (J743)
10644 - Selector Lever
P0919 00 [044] - Malfunction
Gearbox module logged this whilst manually shifting from drive to sport during an overtake, caused ABS fault light and stopped ACC from working until it was cleared.
Address 13: Auto Dist. Reg (J428)
1043 - Automatic Distance Control
Fault Code B10E7 F0 [008]
ACC unit was disabled due to an error on another module or data bus.
ABS 00397 - was a front left wheel puncture. (puncture repaired and fault cleared down)
IMMOBILISER 9456128 - was the Ghost imob blocking the engine start (tried starting without putting code in). (code clears down fine)
Battery Regulator 02256 – quiescent current - Battery monitor detecting power drain from starter battery (about above 50mA) (left the Carista plugged in obd2 PORT overnight)
Address 25: Immobilizer (J334)
9456128 - Engine Control Module (ECM) not authorized
B104A
The Immobilizer has been blocked and is active(preventing the vehicle from starting) this can appear if you have an additional Immobilizer fitter like an Autowatch Ghost.
Even after the vehicle has been enabled and runs the code will persist.
Address 01: Engine (2D2D2-CXEB)
25577 - Engine Start Blocked by Immobilizer
P1570 00 [096]
Ghost immobilizer Blocked engine start (forgot to enter code . . . . again!)
code clears down fine.
31103 - SCR NOx Catalyst Bank 1
P20EE 00 [096] - Efficiency too Low
the ECM does not think your NOx reduction system is working the way it should, too much NOx is being detected.
Address 09: Cent. Elect. (J519)
03303 - Response Closing Status of Rear Left Door
008 - Implausible Signal - Intermittent
intermittent/faulty rear door-lock status switch.
rear door lock carrier replaced by VW.
Address 15: Airbags (J234)
12850432 - Databus
U1122 00 [008] - Implausible Message
[Bremse8 DLC Error]
unknown atm / possibly related to unplugging passenger airbag switch
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Fault in the airbag, needs to be replaced.
B104A
Ghost immobilizer block engine start - forgot to enter code!
Address 01: Engine (J623-CFCA)
5456 - Starter Will Not Turn
P3054 00 [096] - Jammed or Electrical Malfunction
Starter motor BAT+ cable loose causing starter to not engage and turn engine
Address 01: Engine (J623-CFCA) (T5.1)
11866 - Position Sensor for Turbo Inlet Valve
P22D5 00 [096] - Implausible Signal
sensor connector was left unplugged
Address 37: Navigation (J0506) (T5.1)
00862 - Antenna for GPS Navigation (R50/R52)
007 - Short to Ground - Intermittent
Address 56: Radio (J0506)
side mirror damaged by a third party
Address 55: Headlight Range (J431)
5275220 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
auto level headlight settings out of calibration
Address 03: ABS Brakes (J104)
0397 - TPMS Warning
C102D F0 [008] - Pressure Loss
Low tyre pressure.
Address 01: Engine (2D2D2-CXFA)
16230 - Control Module for Instrument Cluster
U1019 00 [032] - Missing Signal for Oil Level/Temperature
Faulty oil sensor
23871 - EGR System
P0401 00 [096] - Insufficient Flow
Blocked EGR cooler
