Okay, but do you have wiring diagram?i didnt work out coding yet
if someone with a T6 which has the button already could post a scan it would help
Yes. Two top ones 100% both with this setup (including diff lock and hill decent).Thanks.
Just to double check, can you please confirm that all 3 above had a factory fitted tracktion disable switch
Hope this helps.
T6 MY16 110kW/150PS DSG 4Motion T32 LWB LHD 16" factory wheels (small brakes) factory towbar
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 Q HW: 7E0 907 379 N
Component: ESC H05 0132
Revision: 00000000 Serial number: 42955000000178
Coding: 557EC0982569867FAA7B037DA483619678F700
Shop #: WSC 02739 790 50316
ROD: EV_Brake1ESCCONTIVN75XGP2_011_VN35.rod
VCID: 40DA4AB14A0ABDE703C-8014
T6 MY18 150kW/204PS DSG 4motion T32 LWB LHD 17" factory wheels (big brakes) factory towbar
Address 03: ABS Brakes (J104) Labels:. 7E0-907-37x-MK100ESC.clb
Component: ESC H06 0133
Revision: 00000000 Serial number: 60508000001018
Coding: 557EC09865668682AA7C0379A684619678F700
Shop #: WSC 02762 790 50316
VCID: 40DA4AB14A0ABDE7328-8014
Edit/one more:
T6 MY17 150kW/204PS DSG 4Motion T30 LWB LHD 17" factory wheels (big brakes) factory towbar
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Revision: 00000000 Serial number: 42906000000003
Coding: 557E8098656A8682AA7D017AA68861A678F700
VCID: 40DA4AB14A0ABDE76D9-8014
A plain one - button for traction control yes, diff lock no, TPMS no, hill decent no.
T6 MY18(19?) 150kW/204PS DSG 4motion T30 LWB LHD 17" factory wheels (big brakes) factory towbar
Revision: 00000000 Serial number: 62278000000628
Coding: 557E809865638485AA7D017AA68B21A678F700
Shop #: WSC 00012 790 50316
VCID: 40DA4AB14A0ABDE7DE5-8014
PS. Up here traction control button is now (MY19) a new factory option for FWD T6. Not too expensive - 30 euros.
I found out how to to turn traction control off on a 17 t6
Turn on hazard lights.
Turn ignition key on but don't start engine.
Depress accelerator 5 times.
You should hear a beep and traction control should light up on dash.
Start engine and drive off.
Hazards have to stay on whole time.
To deactivate turn hazards off.
Hope this helps.
Well done. Can you share how you did it?
I have all the details etc but I’m a little reluctant to put up info in public that could lead to safety implications with the vehicle.Well done. Can you share how you did it?
