Something may be worth looking at IF you removed both the black (T73a) and white (T73b) covers going to J519 (BCM) at the same time during the retrofit?
If so, make sure you have put the cover on the correct plug. The mechanical coding (only allowing the correct plug to fit into the ecu) is done with the outer cover ONLY!! If you get the wrong cover on the wrong plug, it will fit J519 but things won’t work and the heated front screen switch (if fitted) lights up as being on with the ignition off. Also the CAN bus wires will be in the wrong slot.
Took me a while to figure this out when a van was brought to me after someone retrofitted a tow bar as it looked correct and the plugs fitted as they should.
My advise is to ONLY fit wires into one plug at a time, then refit the cover before removing the other cover so as not to get them muddled up which is easy to do due to the limited space to work under there.
Also when removing and fitting fuses, it is very easy to fit the fuse in the wrong slot as they are not the easiest to see. With most group fuse boxes, they only populate the ones used (no spare wiring for other circuits for other options to save money), so have a look with a torch, any slots with terminals in both sides are usually missing a fuse, remove the fuse you just replaced, if it only has one side populated or non populated, you have fitted your new fuse in the wrong slot.
Good luck!
