SPR75
Hi Guy's.
I've a 23 SWB which is quite low to the ground - I've never given consideration to the water tank underneath; anyone ever had any damage or punctures due to a low stance - also, will the 60 litres (full) take it lower to the ground - I suspect so?
Also, my factory LED headlights dipped beam, appears to be as bright at full beam - is this normal; I get flashed in anger every other vehicle?
. In that case, they should be self levelling, unless the change in stance exceeds the range of the system.
