Hey all,
Following this thread after having the flashing coil light of doom with ‘P164B00 Oil pressure switch: Malfunction’
Have since had the brown pressure switch changed, but alas the problem is still there.
Similar to others, occurs around 2k rpm when the engine is warming up. Doesn’t put me into limp mode or limit my speed at all, although stop-start does begin erroring.
A quick restart once the engine is warm and it doesn’t come on all day. Otherwise van drives perfect.
I don’t have access to a VCDS, however I have got a Carista w/subscription, and also the car scanner app (which I much prefer to Carista)
Unfortunately I don’t see an option to run the VCDS test y’all are mentioning (maybe I’ll try and find someone near Oxford that has one I can borrow), but I have tried plotting the oil switch against engine RPM on my drive this morning and this is what I seem to get.
(Drive was only about 10mins, but we did get up to normal oil temps about 3/4 through (roughly when the oil switch kicked in
Strangely there’s nada from the oil switch until a little further into my drive when the engine warms up and then suddenly it starts registering.
Have attached a screen grab of this.
Any ideas? Does this look as though it could be another oil pressure regulating valve?
