It is to swirl the gas flow so that the adblue mixes in properly, rather than a big wet lump which then crystallises.
VCDS > Select > 01-Engine > Adaptation > IDE07903-Adaptation of ash massNext step… how do I teach it that it’s has a “new” DPF, or is there a cleaned DPF setting?
No coding needed.Do I need to code in the new particle sensor? There’s no engine light on…?
Well, in the DPF there surely is no soot to burn. Personally I wouldn't bother. Instead I would run the EGR test to capture the new pressure readings across the DPFWould it be worth doing a manual a regen?
Yeah makes sense mate. I feel we all have such a love hate relationship with these vans haha.So far so good, if it plays up it may somehow become damaged…
It wasn’t really causing any major issues, I have a 204 with somewhat fragile turbos, I cleaned mine to reduce any unnecessary back pressure in hope the turbos don’t explode and scrap the engine.
Thanks for these tips…In summary… it’s a b*****d of a job!
I didn’t remove the prop, I just removed the centre hanger, then let it sit on the more rearward loop, don’t undo the prop bolts, they’re stretch bolts, and the joints are full of sticky black grease… guess how I know…
If you can, leave all the sensors in place, you’ll struggle to seal them properly to stop the wynns cleaner slowly emptying out all over your garage carpet!
And you don’t run the risk of damaging them like I did, that was a £250 mistake.
Doing it this was means you have to remove all the heat shield fixings and shove them as far to the rear as possible, and over to one side, bent them up a bit too, they soon bend back once the fixings are back in place.
I don’t think you’ll get a pressure washer head in there as the front pipe has an angle bent into it, and the rear pipe is pressed and has a slight dog leg in it, I filed it up with water and dumped the contents of my compressors tank into it with my hand binging up the hold as best I could, that really shifted some muck!
Good luck. From the pictures it looks lovely where you are!So the DPF came out today. *woooohoooo!
After chatting with a few mates, I got mixed advice..... some said to leave the sensors in, others reckoned it’s safer to remove them. In the end, I decided to take the risk and leave them in.
I packed the sensor side with bubble wrap and rubber, then sealed it up with masking tape. I poured in a full bottle of DPF cleaner and now I’m letting it sit for a while. I’ll give it a shake every now and then, and later this evening I’ll pour in some boiling water. I don’t have access to an air compressor where I am, so I’m going to try cleaning it out with the Karcher. Let’s see how it goes. Worst case, I need new sensors. Absolute worst case, a whole new DPF. But fingers crossed -> best case, this gets me another 50,000 km!![]()
Just like Cog Head described in his earlier posts, I ran into the exact same set of obstacles. The most frustrating part by far was the H5 bolt on the V-band clamp at the top of the DPF, just after the catalytic converter. It faces upwards -- a truly inspired bit of VW engineering that required body contortions worthy of a Kamasutra diagram. Getting it loose was a real challenge, but once it cracked free, the rest was straightforward.@T6NOMAD How challenging was it to remove the DPF? I'm also planning to do this in the coming weeks, but it sounds like a nightmare job!
