T6.1 rear window washer fluid pipe repair/replacement.
Dorlo
Has anyone had to do this? Mine has split somewhere and I’ve got water leaking from just behind the top of the b pillar. Just wondered if it can be accessed anywhere or if there are any joins in it. Thinking it might be easier to just pull a new pipe through and swap the connections over. Appreciate any input from anyone who’s solved a similar problem.
Did you manage to sort this? I’ve got a similar issue need to replace the pipe do you know what size it is?
In my T6 I found a leak in the windshield on the right side.
I bought these sets: a wiper arm puller and a hose connector, I will repair them in my free time. The size is Definitely 4mm.
Fixed
