T6.1 rear window curtains not fitting
Hi All,
Has anyone Brought rear window curtains for a 6.1 twin slider? I've just recieved mine but don't seem to fit.... the top rail isn't long enough for the window.
many thanks in advance for any help.
Who did you buy them from, and can you post some pictures ?
Pete
did you solve that mystery ?? It looks I have same problem with my curtains from van style ‍ top rail looks a bit short ... or I don't know where to fix it
did you solve that mystery ?? It looks I have same problem with my curtains from van style * top rail looks a bit short ... or I don't know where to fix it
Nope I gave up in the end! I just use blackout fabric when I stay in the van. It’s not that often so can work with that for now.
I have actually give a go and I have installed them but I use longer (mark bottom) rail in the top of the window and shorter in the bottom and they work fine. The only thing is you have to straighten bottom rail as when is bend it is little bit short. hope that helps
