Hi,
Our air suspension controller is complaining about low voltage from the starter battery as the electrics are turned on before ignition. It's fine once the engine is started and the alternator is running.
I measured the voltage (at a 12v socket so there may be some voltage drop from the wiring) at 12.4-12.5 volts before the electrics are on which seems a little on the low side as it would imply a battery charge of around 50%. The van has done some long'ish runs recently so I'd expect the charge to be near 80%. Is this normal, or do other T6 owners get more than this?
Once the electrics are on then the voltage seems to drop to 12.1v which seems extremely low. Obviously I'd expect some voltage sag if it's really under load but it's only really powering a few dashboard lights at this point.
I'm wondering whether we have an iffy starter battery.
