Apologies for perhaps starting a new thread when this is covered elsewhere, but I am being a bit slow and just wanting to check.
I have a vw shunt on the negative terminal but also a few other connections, probably from the camper conversion. I have seen in other threads that this should not be done as the system will not recharge there battery properly and it will eventually go flat.
However, my starter battery has not gone flat (yet), after nearly two years like this. That said, I have a solar panel and not sure whether that may charge the battery. I also have to admit that I added a cheap trickle charger between the leisure battery and the starter battery. I did that after the starter battery did give a low charge/voltage warning but I put that down to the van having been parked for a few days whilst camping with the doors opening, radio used occasionally etc.
Also, when I have connected my OBDeleven to investigate other faults it has indicated battery charging amps high or overcharging or something similar. Is that a symptom of the battery taking more amps/charge than the system expected due to the unmetered usage through the 'extra' connections on the negative post?
Should I move the extra connections to a suitable 'earthed' bolt?
Thanks in advance.
Thanks in advance.
