I've been chasing a parasitic battery drain as after leaving van for a week the starter battery will be flat.
Testing between negative battery terminal and negative lead with all doors shut ect im getting around 0.9a drain.
If I disconnect the positive cable from starter battery to renogy dc-dc 50a ip67 the drain drops to around 0.4a.
Is there a possibility I have a faulty unit or anything else I should be checking in the settings ect?
