Squeeky bum
Jay
Gas Engineer - Baxi Boilers
My bus seams to have developed a squeaky bum. Mainly when going over small bumps at slow speed. I had h&r coilovers fitted last October by @CRS Performance.
I know its had to diagnose with limited info, but would this be more likely to be the suspension bushes squeeking. I haven't had a chance to get underneath to check, just wondered if anyone else had had a similar issue
Hi Jay
It can be a worn spring mounting bush . , it can be dirt stuck around the spring ( stones etc ) and stones stuck in the brake calliper even
It is unlikely to be the shock bushes they are designed to twist as the suspension moves but they rubber so really cant make a squeak noise
Happy to look at for you ?
