(Side Assist) / (Blind Spot Detection & Rear Cross Traffic Alert) retrofit
I meant that seller has already coded the modules for ID.3, or no???
I don't know, I've also asked for ODIS, I currently have OBDEleven, when I get ODIS I'll look at all those things, I don't have much experience in these things either, I'm learning.
I only want to go to PQ35 PDC Module. I have PQ25 PDC Module as Standart. Is it correct that i only need the ne PQ35 PDC Module and the adapter ? Rest ist coding in VCDS ? Or do i need to change ABS Sensors as well ?
Thanks in advance!
Hello guys!
One year later i decided to start research again (no audio warnings for RCTA).
I have 5Q0 radars, BSD is working perfect, RCTA only visual warnings on the MIB.
PDC module used is 1K8919472C. I have only PDC (8 sensors) and not PLA (12 sensors).
ABS does not have the auto breaking option.
Rear axe abs unidirectional sensors.
Now my questions:
1. I need to change the rear axe sensors to bidirectional to have sound warnings for RCTA?
2. Also, I need PLA (12 sensors) for sound warnings or it's enough PDC (8 sensors)?
3. What is the coding in 10-PDC for RCTA? My coding atm is 0031055001.
@Robert: you also had this problem here, how did you solve it?
Update: found the solution for RCTA sound warning. Indeed it was needed bidirectional rear abs sensors. Sound is coming from the rear PDC buzzer.
Coding after sensors change: 03- ABS byte18 bit4 & 6 and 10- PDC byte1 bit6.
My PDC coding now is 0061155001 (no automated Brake).
ABS sensors: WHT003858A rear right and WHT003859A rear left. These are for PQ35, MK6 my case.
Good morning
I installed the 7e0 sensors but I have faults
because I had the lights in the 12v mirrors
I have provided the documents if anyone can help me
THANKS
Or
Do I have to change the radars to 2Q0? if I followed everything correctly...
Good morning
THANKS
Or
Just missing calibration?
Workshop manual - Transporter Electrical system explains how to calibrate using special workshop tools.
You can also use 2Q0 radars with correct dataset and resistors for your warning lights in your mirrors. They have also automatic calibration by driving.
This is a little bit easier.
2Q0 radars allows to activate RTA if you change your rear abs sensors too!
You can find coding, dataset and partnumbers in this thread
so I read pfffff direction vw garage
Or
5Q0907686C with new connectors, do we need to modify the harness at the radar levels? and resistance to light.... not easy
You can use 5Q0 or 2Q0 radars with new plugs.
2 plugs: 1J0974714
Note that you will need VCP or ODIS, if wrong dataset is uploaded on 5Q0/2Q0 radars.
I soldered resistors behind the taillight and rubber grommet.
2 resistors: 1W 200Ohm
Connection of 5Q0 and 2Q0 radars:
Does anyone know what bus the 2Q0 radars are connected to? There are several buses
VW ID.3 Pro perfomance
Connection 3 of running gear sensors CANbus.
then can find small connector have green CAN-H wire and brown CAN-L wire.
The brown sounds very strange for CANbus - unless you mean orange/brown. Then your finding would be the convenience CANbus.
Perhaps the best way forward would be to get proper documentation of the exact vehicle you have.
Please share a full VCDS Auto-Scan.
