I contacted Ring this morning and got this reply, if it helps anyone else. i need to find my number now.Mine also has only six digits BUT those six are lower that that figure quoted from RING. In the email that I had from them it said the number quoted on the box, whether or not he meant on the unit case or on the packing box I don't know. When I get home I will look to see if I still have the original box and see what is on that.
Rod
@travelvolts whilst on the subject of the Ring, would you be able to clarify this for me, please; there’s no ignition wire to the unit, so I presume that, through it’s connection with the starter battery, it knows when the starter battery is receiving charge from the alternator.. So if I needed to charge both the starter and the leisure battery, could I just charge-up the starter battery (with it in situ via the cigarette socket) and expect the Ring to take charge from that and feed it in to the leisure battery (almost as if the Ring thinks that the van engine is running, because you’re loading the starter battery with charge)?
Agreed, sorry for the error.Not if you connect the charger negative cable to a body earth instead of battery negative. But I agree, I would avoid this scenario. It is never recommended to constantly charge a starter duty battery.
