Bear Member VIP Member T6 Pro 5 Jan 2019 #1 Hi. Has anyone done or seen repeater lamps in the door mirrors, like a golf etc ?
Pauly Senior Member VCDS User Admin Moderator 5 Jan 2019 #2 I have a set fitted to mine that flash an arrow shape, got them from Van-x, fitted best part of two years ago Van-X | HEATED LED Wing Mirror Lens (SET OF 2) for VW T6 Transporter
Skyliner33 Senior Member VCDS User VIP Member T6 Legend 5 Jan 2019 #3 Do these heat up any better than the OEM ones?
StudleyGlass 150 DSG Kombi/Caravelle/Air-ride VIP Member T6 Legend 5 Jan 2019 #4 @roberts has modded his mirror if you look here Power fold mirror retrofit with fold on remote lock Hinkley WRC have modded there T6 mirrors with indicators as well. Not a easy job but looks great IMO Who’s Gonna Be First Then?
Bear Member VIP Member T6 Pro 5 Jan 2019 #5 I have a broken mirror assembly , alloy part has broke, but the casings are all good. Just need to find a mirror repeater that sort of fits.
J Jean-Louis Bourdon Firmware Engineer VIP Member T6 Guru 9 Jan 2019 #6 i thought i had seen one with them, but looks like i was fooled by reflective stickers looks good (enough) too?
Vanman Senior Member T6 Pro 11 Oct 2019 #7 Pauly said: I have a set fitted to mine that flash an arrow shape, got them from Van-x, fitted best part of two years ago Van-X | HEATED LED Wing Mirror Lens (SET OF 2) for VW T6 Transporter Click to expand... Are they easy to fit?
Pauly Senior Member VCDS User Admin Moderator 11 Oct 2019 #8 Yes the glass is but you need to run the supplied cable down to the side repeater in the wing and connect it
Robert Senior Modder VCDS User Moderator VIP Member T6 Legend 26 Oct 2019 #9 and wiring here ---> Power fold mirror retrofit with fold on remote lock
