Real World Review. B14 Comfort Vs H&R’s.
Two7Five
Bike botherer.
I thought I’d add my experience to the favourite suspension question…
Van 1: 150 manual. Panel van. Highline spec. Bilstein B14 comforts. 25k covered.
Van 2: 200 DSG 4 Motion. Panel van. Highline spec. Was talked into a set of H&R’s after reading about headaches on heavier vans with the B14’s. 5k covered so far. (This van is ultimately replacing the 150)
I drive the vans hard. They occasionally carry weight, but mostly enduro bikes and gear, so about 400kg loaded.
The DSG 4 motion is about 300kg heavier std.
My other current vehicles include an M2 and a modern 911, plus a defender and Mini Countryman JCW. I like a ‘sporty’ drive.
On arrival to me the DSG had vw lowered coil springs on it from the dealer. They were the worst set of springs I’ve ever had. In my youth I’ve cut stuff down, so this is quite a statement.
The B14’s on my T28 van were/are great. No squeaks,rattles, bangs and the handling was a vast improvement on std, plus actually very comfortable. It’s on staggered 20’s with 35 profile continentals. (The DSG 4 motion is on exactly the same wheels)
The H&R’s are indistinguishable from the B14’s. The ‘feel’ and quality are on a par.. I think they look a bit cheap tbh. The coils are of course smaller and a truer ‘coil over’, but honestly I don’t agree with the patter about snapped coils catching tyres. I’ve had an OEM vw spring do this in any case. That van did 100k. (Was an 06 T30 170. Bought new)
The H&R’s were fitted by CRS. They were no better or worse than any of the main dealers or suspension specialists I’ve used in the past. They’d run out of paper mats and hand wipes on the day they did my van it seems.
The B14’s were fitted by Leightons. The van had a spoiler fitted and a set of wheels at the same time. (Same as above, but with additional body shop dust covering the van interior)
I made final adjustment to both my vans on my drive. I used some bilt hamber wax on the threads and cleaned up/tidied up some of the work done on both vans. I prefer to do my own stuff, but was/am busy.
Both set ups fitted within the last 12 months to new T6.1’s.
It’s not a double blind, the DSG 4 is much heavier, and you can feel it in the driving, but as far as road holding, comfort etc (I’ve jumped out of one and into the other) they’re both fine/a vast improvement on OEM. The standard van in my opinion isn’t great. The VW ‘sport’ springs should be removed from sale, as they ruin a bad start.
I have both vans set up at 400mm from wheel centre to the wheel arch all around. Both vans arrived back +/- >10mm difference from wheel to wheel. Close enough, but I adjusted in any case. They could both go a LOT lower. They could both easily go up too.
The rear springs on the B14’s do bind. I’ve had more weight in than I should have had on a few occasions. They haven’t ever got any worse. The springs on my M2 are the same, as they are on the JCW, make of this what you will.
The bigger question is was it worth all the extra cash to hop up to the 200 DSG 4 motion out of the 150 manual…. Ask me again when it snows and I might say yes.
With the additional weight in in bad weather, then yes, it will be worth it - offset by the extra running costs in fuel and servicing.
Good impartial write up!
I've just gone from 4yr old B14s to H&R coilovers in conjunction with H&R ARBs on my T28 camper and the difference in the vehicle feel is negligible.
Sadly it hasn't been a case of the massive improvement in handling seen when going from the lousy stock VW suspension to the B14s.
I would say that the H&Rs are still an improvement and Steve at CRS is a genuine guy managing to squeeze my van in at pretty short notice.
Whether the thicker ARBs mask the compliance of the coilovers to some extent by forcing the vehicle to stay flat to the road I don't know but it's probably more a case of diminishing returns much like horsepower versus top speed.
The bigger ARB probably makes more of a difference in terms of vehicle ‘attitude’ than any of the suspension would. (There’s a few tests out there for similar/bang for buck mods on this type of thing)
Seems we’re largely in agreement tho. I just wanted to add my experience to counter some of the evangelist/ magician stuff. I had no bother with my B14’s, sounds like you had them on a camper as well, aside from wanting a better ride, was there any other reason you changed over?
Have to say I’m much steadier in my big (sprinter) camper as I don’t want my crockery all over the show
My T28, although a highline 150 was / is otherwise ‘base’ in terms of weight and ARBs etc. with the B14 (comforts) on, it’s very, very good for a panel van, and embarrasses plenty of spicy saloons (admittedly probably being driven at a mediocre standard by a rep in pursuit of stapler sales)
Sadly with my Billie's one of the front springs snapped last year (luckily while reversing on the drive) so replaced as a new pair of springs then and spotted while on holiday two weeks ago that the smallest lead in coil on one of the rears had shuffled off too so rather than replace the rear springs I took that cost off the price of starting all over again.
Mine weren't the Komfort model but original monotube gas type and coming up to 3 1/2 yrs old, I'd say putting them on prior to adding the ARBs there was definitely a more plush ride, the ARBs made everything a bitt stiffer and turned up to 11 for tautness at the expense of some blurred vision.
Good stuff, I think that’s about the norm I’m afraid. My (race) mechanic friend has just put a spring on his (standard) Vivaro van for its first MOT.
Dare say the original VW ones might have lasted a bit longer. The H&R springs I’ve had on LWB in the past have done about 5yrs before they’ve started pinging off pigs tails.
Update on this.
Have had cause to be back under the van this week. The newer van has done very limited miles on the ‘better’ set up (this is on the T32), and sounded like an old nova. Some rather sloppy ‘torquing’ of the drop links meant they came loose…. Suggests they were toques using the ‘DuggaDugga’ approach.
Sounded and felt like it was a pogo stick over sharp bumps.
The performance of the Anti roll bars are marginally different from H&R to B14 because the B14 doesn't have the repositioned drop link bracket , The one time we saw a TUV certificate for B14 it clearly stated to get approval a longer drop link is needed . The picture below also shows the difference . Not sure how quantifiable the difference is but for TUV to make a mention i guess its noticeable.
The damping is also quite different in these kits as well as the height range .
