Power-Latching Sliding-door kit from Kufatec
It’s a fairly easy mod to do. Not sure if @Pauly is still supplying the bits but there is more info here
Thats quite expensive if its just for a single slider, I paid not too much more than that for a single slider and a tailgate soft close using VW parts.
Parts supplied by @Pauly
I got someone else to fit the kit for about another £200
Good morning
I’m after some help/advice. I’ve fitted a power latch kit suppled by Kufatec and it’s never worked. After the van being at Bognor motors and on their advice . I’d like to replace all the supplied wiring and connections . I’d also like to check that I’ve connected to the right places on the existing wiring. ie where to connect on the rear door and what pin on the bcm to connect to. As advice on different posts seems to contradict the supplied instructions. I’ve never been happy with the quality of the wiring supplied and I’d like to replace it. Where can I buy the correct 8 pin connector and pins/terminal for the control module? and has anyone got a wiring diagram or instructions on fitting the power latch ? thanks in advance. Steve
@Stannards , would you be able to share the part numbers of the parts that you received from Kufatec? (apart from the wiring)
I think besides a control module, there is a a bracket and something else supplied...?
As far as the connector, pins/terminal go - I intend to order mine so I can order 2 of each (in case you're able to wait for the shipping to arrive).
sorry Eugene it all came as a kit so I don't have individual part numbers. If you go on this site onlineparts24 you can see all the parts you need.
Success. Iv finally got my power latch to work. After following @Pauly advice/ instructions. I wired the way he suggested and it all works fine. I don't understand why Kufatec would make it so complicated. Thanks @Pauly for you help. I just need to find where I can buy a 8 pin connector and a set of pins for the control module as the one supplied is a bit crap and I like to replace it . Thanks again
Got myself some connectors and a control module today. Still looking for part numbers of the control module bracket as well as the covering lock carrier. Other chaps on this forum either don't seem to know or don't desire to share this info :)
Will post more info in the general soft close thread where I will share part numbers and cable pinouts if I manage to install everything successfully.
Hi @eugene I know this is an old post but did you ever complete these retrofit? I have all the parts needed from a caravelle but could do with some advice on wiring / pin outs.
Thank you
Thank you
Hi. Softclose is installed. The drives for the powered tailgate was a cancelled project. I am not going to risk the health of my family.
Thank you for getting back to me. I am only thinking of soft close. Would you have information on the wiring please?
