Power-Closing Sliding-Door Retrofit
And below is my current (onboard) BCM(second hand from unknown T6 most likely LHD ;)).
EDIT: FATIGUE DETECTION was already included.
Code:
Sunday,31,January,2021,16:35:24:50413
VCDS Version: Release 20.12.0 (x64)
                Address 09: Cent. Elect.
Control Module Part Number: 7E0 937 090 B
  Component and/or Version: BCM PQ25 Max4 H81 0744
           Software Coding: B8DA7DBF48E3348393288FC4FE8B9EF490A473F160CD79D0330403BF0840
            Work Shop Code: WSC 02737
                      VCID: 2A0CFB4F0CF3678B0D6-807E
Advanced Identification
     Serial number: 0982 154161731
     Identification: SME-RBG
     Revision: B9081001
     Date: 08.08.16
     Manufacturer number: 0005
     Test stand number: 1688
Flash Status
     Programming Attempts(application): 0
     Successful Attempts(application): 0
     Successful Attempts(data): 0
     Programming Status: 00000000
     Flash Date: 0000.00.00
     Flash Tool Code: 00000 000 00000
Software
     HiSpd Net: 01.01.00
Misc.
     Hardware number: 7E0 937 090
     Workshop System Name: J519
     Equipment/PR Code: 0000000000000000
     Dataset Number: -----------
     Dataset Version: ----
     End of Line Equipment Level: --------------------
VCDS Info:
       Labels: 7E0-937-BCM-V1.clb
Interesting that none of them show datasets
I think this (missing or present) Dataset Number info is completely irrelevant.
I have uploaded number of data sets to different modules
and this ADVANCED ID(Dataset Number) was almost always blank after the upload.
Please see my video below( as per @mmi instructions).
There is no point for dash buttons verification as @Pauly says they function correctly.
I think I have just noticed something here !
When you push left button it says left, when you push right button it says light
When I push mine it says light, so does my van think it opening the other side, the door I don’t have ?
Try to switch to the other side on these two Bytes.
Byte 07 Bit 0 Central Locking/Rear: Sliding Door Left installed
Byte 07 Bit 1 Central Locking/Rear: Sliding Door Right installed
Byte 26 Bit 0 Rotary signal for sliding door on the left via CAN data bus
Byte 26 Bit 1 Rotary signal for sliding door on the right via CAN data bus
Maybe test all possible combinations.
Obviously "light" means "right" :D.
EDIT:
We need to give out to Ross-Tech.
  • Haha
By the way I suspect that if you had twin slider remote you would be finished a good while ago.
LHS or RHS button would work for you.
Thats my thoughts at the moment, make the van think the other door is there so if i reverse all the coding to right door then remove left door module from gateway and add right door in it MAY work ??
This is awesome, I've been refreshing this thread to read it as it happens like a news event :think smile bounce: Don't think I can go to bed until it's resolved
I understand what has happened now, i have just been back to etka to look at key listings, they are based on pr codes, GX5 = right elec door & GZ5 = left elec door
I have ordered the key for GZ5 but when i look at the key listed for GX5 it has an identical part number, either one gets you the key i have
Theres either a mistake on etka or the left door only key doesnt exist (which i find hard to believe)
I can obviously order a 5 button key that has both doors on but that feels a bit like cheating
Think my only option is to find someone with and electric slider on the left only and get the part number off their key ?
