Parking Sensors And Bike Rack
Gavandi
Have searched threads and various info touching on my query.
If you put a towbar bike rack ie Thule tilting..... do the parking sensors keep beeping or
do they ignore the rack and bikes?
Sorry, in advance, if a bit simple question .
Yes if you have the correct wiring loom for the electrics, amongst other things it disables the reverse sensors when the rack is connected. If you only have a bypass relay then you’ll have to disable the sensors manually.
If wired up properly the van sees the bike rack the same as a trailer
Cheers guys.
Its a dealer fitted removable towbar and electrics so should be good.
Much appreciated
