Hi all,
Looking for a bit of guidance (or confirmation).
I've had my van for less than 6 months. 2.0 BiTdi with 145k on it now (139k iirc when purchased). I had the oil sampled after 650 miles as the dealer said they serviced it so I had to wait for a 'good' sample. Results came back fine on the aluminium content but it showed high soot content, leading me to believe they never serviced the van. The van has the revision D cooler on it.
Anyway life got in the way and the van drives great and I forgot to service it myself. Last week I had the Oil Pressure light on, but would go off again within a second or 2. I then reminded myself about the oil potentially being very old so changed oil & filter and the light hasn't came back on since but I'm trying to make sure I'm not masking a fault so I went today and bought a pressure tester.
Engine warm and pressure at idle - 15psi
at 2000rpm - 25psi max
Reading online I'm expecting much higher pressure readings is that correct?
If so, am I on the road to a goosed engine?
When the oil was drained there was no metallic tinge to it, just very old looking.
TIA for any help.
TIA for any help.
