Especially if run on heating oil (kerosene).The advantage of the diesel is that it should hopefully be cheaper to run than the electric
I was looking to run it on a mix of red derv and Kerosene to help with the pump lube but it seems UK Kerosene doesn't kill the pumps as much?Especially if run on heating oil (kerosene).
An oil fired central heating fuel pump is a pretty delicate item and they manage OK unless left static to long, incorrect filtering or water content too high.I was looking to run it on a mix of red derv and Kerosene to help with the pump lube but it seems UK Kerosene doesn't kill the pumps as much?
What do you use to power it? Do you use a battery or 240v to 12v transformer?I fitted this in my garage 2 years ago and it’s been a game changer during winter months tinkering with my classic motorbikes,
That’s what I bought and wired up to the heater.You can use a battery but I'm using this as a temporary measure to get it up and running whilst I decide on a permanent solution
Hi @Lightrofit would you mind posting a link of where you bought it or let me know the manufacture please?With 'er in doors not allowing me to set up a work station in the house, I grabbed something to make working in the garage more comfortable...
More fool her, I'll be spending way more time in the garage now!
Wait, was that her plan all along??!?!
Hi, sureHi @Lightrofit would you mind posting a link of where you bought it or let me know the manufacture please?
I have been reading that it's commonly known that there is no such thing as an 8kw heater, just sellers falsely advertising the 5kw as an 8kw. Have you measured yours to see if it really is 8kw? Or are the information sources I've been reading misinformed?I’ve edited post 8 as it wasn’t a 5 kw heater I bought but an 8 kw diesel heater.
John.
Thanks mate
I’ve heard the same, but I wouldn’t know how to measure if 5kw or 8kw, alls I know it heats my 22’6”x10’6” garage really well.I have been reading that it's commonly known that there is no such thing as an 8kw heater, just sellers falsely advertising the 5kw as an 8kw. Have you measured yours to see if it really is 8kw? Or are the information sources I've been reading misinformed?
