MIB2 PQ Discover Media - Infotainment mods, upgrade, FEC / SWaP
For Anybody who wants to add inCarComminication (voice enhancer ) to their van i found a way works without vagcanpro. As i am using a skin i don't need the fec but i think it will work that way also. with an elm adapter and carscanner app upload attached dataset to 0x7000.
0x01,0xA0,0x51,0x41,0x43,0x46,0x01,0x00,0x0C,0x00,0x94,0x00,0x44,0x22,0x53,0x57,0x43,0x48,0x0E,0x00,0x0A,0x02,0x11,0x01,0x09,0x02,0x41,0x01,0x0C,0x02,0x4B,0x02,0x26,0x02,0x50,0x41,0x52,0x4D,0x7A,0x00,0x3D,0x00,0x41,0x28,0x00,0x03,0x18,0x41,0x38,0x00,0x0E,0x00,0x41,0x80,0x01,0x42,0x00,0x41,0x40,0x1F,0x03,0x00,0x41,0x01,0x00,0x05,0x5C,0x45,0x52,0xF4,0x00,0x00,0x00,0x00,0xF4,0x01,0x20,0x00,0x00,0x30,0x41,0xD0,0xFD,0x01,0x30,0x41,0x32,0x00,0x08,0x14,0x41,0x38,0xFF,0x06,0x14,0x55,0x3E,0x00,0x96,0x00,0xB3,0x00,0xEF,0x00,0x17,0x02,0xB0,0x04,0xDA,0x02,0xCC,0x01,0x3C,0xF8,0xE3,0x03,0xC8,0x00,0x9B,0x01,0xC7,0x11,0x1E,0x05,0x37,0xF9,0xEA,0x04,0x61,0x03,0x0A,0xFC,0x25,0x19,0x00,0x00,0x77,0xFB,0x0F,0x00,0x41,0x01,0x00,0x02,0x0C,0x81,0x00,0x00,0x00,0x00,0x03,0x0C,0x81,0x00,0x00,0x00,0x00,0x0D,0x00,0x41,0x80,0xBB,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x31,0x30,0xD2,0x4E
Hi. i also not allowed to download it. I already installed 0478T is there any change to worth to upgrade to 0480 ? thank you.
I don't know. Do you know where to get the 0478T?
DO you have a upload Link , than I can provide you the 0480T.
Hy together. I've been reading through this thread for some time, because I want to enable some features like app connect, mirror link,carplay, voice control, etc. and want to install the toolbox. My discover media has Fw 468 now and due to several posts here, I won't really get benefits if I update to 478 or 480, so I just want to install just the toolbox without updating fw, but I don't really found out if this is possible?!? I can't find TB with fw 468!
My 2nd question: Is it now possible to patch mib2 to enable app connect, like in the vid from mr-fix, or do I have to buy a code?
I'd be happy wether someone could answer my questions.
Thanks.
after a block, raz and I installed MST2_EU_VW_PQ_P0478T
but the language is English or Chinese
I have a functional toolbox I did an update the language is German ....
How to get it in French? (no one is perfect)
by going to 480?
Thank you Gerry
by going to 480?
Thank you Gerry
I dived back into it and it"s great but in 480 version
good evening
gerry
Finally got the driver voice amplifier working thanks to some brainy folk on here and shed load of googling. If anyone else has activated it but it's still not working, check out Mr-Fix on YouTube. Look for the dataset video. Use the same app as him.
When you first open the app go to settings/info and enable "experimental features" for the dataset feature to show.
hello guys, someone can give ma an eMMC dump file of 5C0035680E with DAB, i have replaced the emmc and now i dont have the dump file. THX
Hi
My 5C0035680F unit from a T6, installed in a T5.1 SW:0472, worked fine after the patch. I changed the software to P0478T and now I don't have the radio, navigation, phone, etc. on the instrument cluster. Of course, I don't have the OPS graphics on the T6 coding. What should I do? Coding? Adaptation? Why don't I have any information on the instrument cluster???
Hello, I'm new here and have been reading along for a while. I have a T6, built in September 2017, model year 2018. It has a Discover Media system with navigation and two SD cards. Factory radio, not CP (Combination Package). Software version was 0468T. Developer mode is enabled. I updated to 0478T. What do I need to do to get the car menu and tiles working? The off-road menu works, but not the oil temperature. Do I need to replace the ZR HMI? I've read conflicting opinions. I have the Toolbox on an SD card, but haven't installed it yet. I'm using OBD11. Can anyone help? PMs are welcome. Is there any ready-made software for my problem? Ideally, someone with a black T6. I'm a complete computer novice. Thanks
IMG_7674.webpIMG_7673.webpIMG_7672.webpIMG_7671.webpIMG_7670.webpIMG_7634.webpIMG_7766.webpIMG_7772.webpIMG_7773.webp
