Thanks, the three minutes is just to capture full glow plug post-heat period (two minutes) + a minute of running without glow plugs. The log was about 4 minutes - just perfect!Morning,
5 degrees here, started and lumpy
Ran the recording, but don't think I got the full 3 mins :/. (tried to set a timer in google and didn't start DOH!)
Tried to do it again, but by this point the engine was running better already :/
Let me know if its ok
Thanks again for your help.
Any loss of coolant?All fine till start of second week in Dec 24,
Difficult to say anything definite. Good thing is that the issue can be seen clearly in the data - but what's causing it is a challenge. I'm fairly confident it's an issue with a cylinder (of four). Possibly an injector is playing up. Probably need to start from basics - compression test, etc.Thanks sir, a lot of info there, don't know what to make of it![]()
That's a good thing!No loss of coolant
Well, I was hoping the recorded injection speed by cylinders would help to pinpoint which cylinder is the imbalanced one but I'm not exactly sure how to interpret small variances between cylinders.Anything else I can do or need to wait for garage and hope they can find the cause ... :/
So if you could make a new recording but using the data items below - interested to see if there is a correlation between these and if something sticks out. Again preferably a lumpy running - 3 minutes.
IDE09327 Cylinder 1 bank 1 internal momentIDE09328 Cylinder 2 bank 1 internal momentIDE09329 Cylinder 3 bank 1 internal momentIDE09330 Cylinder 4 bank 1 internal momentIDE12085 Fuel injection time deviation: cylinder 1IDE12086 Fuel injection time deviation: cylinder 2IDE12087 Fuel injection time deviation: cylinder 3IDE12088 Fuel injection time deviation: cylinder 4ENG126008 IN_Injection_speed_injector[0]ENG126009 IN_Injection_speed_injector[1]ENG126010 IN_Injection_speed_injector[2]ENG128778 IN_Injection_speed_injector[3]
Let's hope the garage have the experience and can nail it down right away.Oh no, sounds expensive :/
It's normal as the glow plugs did their pre-heat when ignition was turned on, thus the plugs are already cooled down. Well, I just wanted to capture also the cranking (and thus make it last a bit longerOne thing though, when I turn the IGN on and take my time to tick all items then go to start engine, it takes 4-5 turns of starter to start, like its flooded with fuel. is this normal?
Thank you for making the logs. They are very helpful - as I can compare them with (still) properly working engine - to understand what to look for.Thanks again for all your help, don't fully know what i'm looking at but helpfull to know its showing something.
Thanks, and if it's not too much trouble could you also make a recording when it's running smoothly - for comparisonThanks sir, will do this first thing tomorrow, so its nice and lumpy again![]()
Heres hoping, VW garage, so will see....Let's hope the garage have the experience and can nail it down right away.
Perfect that will help thanksAnyways, to avoid the long cranking with VCDS - when you have ticked all the items - turn ignition off and immediately back on and to start - this way the glow plugs do their heat up and engine starts right away.
VCDS (or actually ECU) will stay alive during this short ignition off period. Actually ECU stays alive a few seconds after turning ignition off.
Thanks, and if it's not too much trouble could you also make a recording when it's running smoothly - for comparison![]()
Thanks. Just idling - it's easier to compare.No worries, with the same options ticked? (IDE09327 Cylinder 1 bank 1 internal moment... etc)? and just idling or driving?
fillings through the fuel system???Your symptoms sound identical to what my van suffered last year. End result was filings through the fuel system, I really hope it ain't that, but all sounds very familiar
That's caused by the HPFP failing. (The metal in the fuel)
That normally needs a.new HPFP. New injectors. And a full tank and system flush.
Definitely an expensive job.
Agreed.But this can't be whats happened to mine, why would it run fine after initial lumpiness? surely it would cause more issues as the RPM increased?
would this be covered under extended warranty? as the pump is after the filter, nothing to stop it?
Agreed.
HPFP failing will normally result in a crank-no-start.... So non runner.
Thank goodness
Well ruled that out![]()
Thank you very much. Below just first impressions as didn't have much time to look into.Ok, done a number of recordings (attached), as I know you love the dataexplained below
Log-02
IDE09327, IDE09328, IDE09329, IDE09330 etc
IGN ON, then cold start (5 degrees)
Lumpy :/
Cylinder 1Log-04
IGN ON, then start after long drive (Regen finished by this point)
Felt smooth now
Cylinder 4 data - interestingly the first 20 seconds are quite different. Does the "loss" of torque mean that engine was almost running only on three cylinders?
Cylinder 4 - nice and smooth...
Once ticked you can save them into a file - and next time use that file to load the items in one go.take my time to tick all items
Based on the blockmap data item below - no.Or even timing being out? :/
Not likely. However, the blockmap data shows there is a significant soot "stress" on the DPF but manageable this far.With the lumpiness when DPF started regen, could this point to issue with DPF or the EGR etc?
Well, could be a timesaver if they are willing to listen customerGot van booked into a VW garage next Monday, should I just let them troubleshoot from start, or let them know any info here?
IDE00182 Camshaft adaptation intake bank 1: phase position = 1.2 °
The "soot measured" is normally lower than "soot calculated"
IDE00434 Particle filter: soot mass calculated = 15.22IDE00435 Particle filter: soot mass measured = 18.16As soon as the lumpiness has been resolved we could take a closer look on this
Well, could be a timesaver if they are willing to listen customerI would show the pictures from post #37.
I believe the injector return flow test might be the way forward - see below
[T6_measured] Injector failure
Keyword “loud knocking metallic noise from engine”. VW has published in September a service note which can be found with vehicle's VIN. The sound clips from my engine (150PS, EU6) with comments on 21 Oct 2017 in thread Tick over noise EDIT: audio files from the thread copied here as...www.t6forum.com
Also the thread below worth to read
VW T6 (2018 cxha) - mystery engine jerks and judders av 2-3k rpm problems
Hi T6 forum, Hello from . (New to this forum, but done countless hours of searching for simular problems.) I'm calling out for some help/advice with our engine problem. Long story short(ish).. We bought a "project" car with broken timing belt (toothed belt). Belt was split, but not broken...www.t6forum.com
