phantom-uk
After carrying out a cylinder head replacement following the VW workshop technician manual, I’m now ready to install the camshaft housing onto the cylinder head.
According to the manual, it asks for a 2mm bead of liquid gasket applied as shown in the accompanying drawing.
My mechanic advisor tells me to apply it on the flat surface of the camshaft housing, as this is the usual place to put it for flange joints and where he has always applied it to.
But the workshop manual maybe suggests that the bead goes into and follows the groove that sits on the inside edge of the camshaft housing flange. Incidentally, the groove in the camshaft housing is 2mm wide. And the pink line that is shown in the workshop manual is exactly where the groove is on the camshaft housing.
All advice welcome. Thank you.
