LED headlight on drivers side working on passenger only
exoticdevil
Norwegian member
Hello everyone!
I have brought used LED light for my T6 for driver side. Conected, but low and high beam not working.
After long day og trying figuring out why it's not working came out something stange. Looks like headlight is coded for a wrong side.
It is headlight with part number 7E1.941.035A for driver side. But one more strange sticker on headlight saying 7E1.941.036A with some marking. I have never seen something like this.
After i have conectoed headlight to a passenger side, everything works. If i try orginal passenger side headlight, it acts just a same like it's conected on wring side. DRL on, no high or low beam.
So looks like that drivers side headlight is code for pasenger side. Need to recode somehow. I have VCDS, but i cannot connect or not getting answer from controller 4E-Ctrl Head RR and 5E-Ctrl Head RR.
My question is if i can do something with VCDS in this case to fix it? Maby reset headlight controller some how? :)
Hmmm... T6 does not have 4E nor 5E. The LEDs are controlled and fed by BCM (09).
Did you check thread:
Hello everyone!
Can you please provide us with some extra info? Why did you buy this headlamp? Is it replacement of a faulty unit or retrofit? Maybe you could post complete VCDS AUTOSCAN with your original components onboard? Another words before you have replaced anything.
Reactions: mmi
