What is that a picture of?View attachment 255285Grrrr bloody sharp edge of seat base!!!
Wonder if I can fill / seal with something durable
WorktopWhat is that a picture of?
So all good?Tbh it's probably not far off, but remember the fogstar BMS doesn't read anything under 1a.
However, 13.4v is very close to fully charged, you'll see the voltage very quickly rise to 14.2v if you've got a charge coming in. 98% to 100% is 13.5v to 14.2v (roughly).
Yes, the voltage in bulk charge phase will rise slowly to about 13.5v at about 98% SOC then rapidly to 14.2v at 100%, then when the MPPT goes into float mode it'll drop down to 13.5v.Where are you getting those voltages from? The recommended charging voltages for fogstar drift batteries are 14.2v in bulk and 13.6v in float - i.e the other way around from what you're quoting there. This is common with most multistage charging configurations, the voltage is higher in bulk charge and then backs off in float when the battery is essentially fully charged.
I don’t understand any of this, I think from what’s being said my system is okay.
I know when the DC to DC is on the battery voltage goes up to 14 I think.
It’s fine. Just use it and let it do its business and all settle down. You’ll then build up some data to analyse its performance.I don’t understand any of this, I think from what’s being said my system is okay.
Yep, so with the DC-DC and the MPPT they both get the battery voltage to 14.2v which is 100% charge, but the DC-DC as it's normally operating at a higher output which will be sending a higher voltage to the battery. So you might see higher voltage at the battery at the same state of change, depending what's charging the battery. But at the end of the day the only voltages that matter are 14.2v, which is fully charged, and 13.5v AFTER 14.2v which is the battery being kept at 100% charge.I don’t understand any of this, I think from what’s being said my system is okay.
