The van is a 2014 T5.1 Shuttle DSG. Occasionally, when I go to start the van the key will only turn to position 1, it sort of feels like it would if the steering lock was on (it isn't, the steering wheel is free), sometimes pushing harder on the brake pedal will allow the key to turn, although this could very well be coincidence. It feels like it has a lock to stop the van being started without the brake pedal being pushed OR if the gearbox isn't in park. I have read a few posts about the van not starting, but they sound like the keys is turning, but nothing is happening, thats not the issue I'm having.
I'm wondering if its an issue with the brake pedal switch or similar (although I'm focusing on the brake purely because once or twice pushing the pedal harder solved the problem). It does seem to be getting worse, I had one episode where i had to keep removing the key for about 10 minutes before it finally turned and started. Just a note on that episode, the wheels were turned to point to the left, although the steering lock definitely wasn't engaged.
Anyone else had this issue?
