Brand new 7.5 ... went back into the garage today as this fault occurred after another fault was fixed and they traced it to a larger fuse!
crisis averted for now.
think I need to get a fuse tester!
Hi, I too think I’ve just blown that fuse, my step lamps and front interior lamps aren’t working when I went to replace one of the step lamps.
question is I do really have to take off what looks like a big panel just to get to the fuse box? I’ve removed to front (tease panel) panel, I can now see the fuse bored (eyes on stalks like a snail) but with size 10+ hands I don’t have a chance of getting my sausage paws in there.
Blown a fuse changing interior bulb and can’t identify the right one, changed all the fuses as per the previous post and no joy
So hard to get to the fuses with massive hands, lost loads that have slid under the rubber matting, totally ridiculous place to put it wit an access hatch that doesn’t allow acces to the whole board, tut tut
Can someone please help I have blown the interior light on my T6 I can’t find the correct fuse to replace I have also noticed my back lights don’t work and the puddle lights don’t work either :(
www.t6forum.com
If that's not blown then you could try disconnecting the starter battery for a few minutes.
Just to add here, I shorted the interior light and the light went out, as if the fuse was blown. I checked the fuses and all was ok. Then I started the van and the interior lights were working again. The BCM must have some type of self-resetting fuse and this reset was triggered by starting the van.
Hi, I did exactly the same the other week and folks on this forum sorted me out. Go to the fuse box below and to the right of the glovebox. On the left hand side towards the bottom below two green fuses is a 7.5amp fuse (about 5th up from the bottom) this is the fuse.
If after you have changed this and you still have the fault you may need to reset the BCM. Do this by disconnecting the battery for a few minutes then turn on the ignition.
This fixed mine - good luck.
Just picking up on this discussion thread as I seem to have exactly the same issue with my interior lights going out. I have changed the fuse (7.5 amp, 5 slots up from the bottom right) but no interior lights still. Any other ideas?
