Injector help
Leekyladd
Evening :)
I ran a test using vcds, I’m no wizard on the diagnostic side ,
Fuel injector time deviation cylinder 1-25us
Fuel injector time deviation cylinder 2 - 24us
Fuel injector time deviation cylinder 3 - 23us
Fuel injector time deviation cylinder 4 - (-72us)
I’m I thinking right that injector 4 needs replacing and the other 3 are now compensating for the faulty 4?
Engine coolant @ 90 when test done.
Injector deviation when added up should = 0 so actually doesnt look bad but i thought it was added in pairs not all four but im not 100% ?
Well I say test I’ve done the deviation of the injectors , just trying to track down the cause of it!
Why don't you do the misfire count live data and accelerate to see if you can replicate the misfire and see which cylinder it occurs on?
I’m investigating a slight misfire in 3rd gear on acceleration, very slightly hesatant.
Any back story?
Could you please create VCDS Auto-Scan and full engine blockmap files please?
1) Full VCDS Auto-Scan
2) Engine blockmap - Ignition ON/engine OFF
3) Engine blockmap - Engine running at idle
4) Engine blockmap - Engine running at idle - 3 minutes after startup
5) Engine blockmap - Hot engine idling - after minimum of 15 minutes of driving - please turn off Stop/Start
How-to create a blockmap file:
[VCDS]​
[Applications]​
[Controller Channel Map]​
- Single Controller Address = 01
- Login or security access code: Leave blank​
- Function: Measuring values
- Output: CSV file
[Go]​
The result (TXT and CSV) files are saved into dircetory C:\Ross-Tech\VCDS\Logs
Please attach the files here.
Any back story?
[VCDS]​
[Applications]​
- Output: CSV file
[Go]​
Yep will do this tomorrow and post my findings :) thanks mate
