That's an interesting question - my guess is the TPMS handles each tyre (or perhaps axle) separately thus it should work just fine.Q2: Would it bawk if I had 275's on the back and 265's on the front?
It’s not a great system. I’ve had it on my golf where two tyres went down and it didn’t pick it up because it was two at the same time. Must compare them against each other Done about 80 miles since activating indirect TPMS and no errors or reset requests have popped up so it seems OK with my ever so slightly different profiles on the fronts v's the rears. I guess it logs each individual wheel rotation v speed and pings when one changes. We shall see, but hopefully not.
What is the exact size of your... it seems OK with my ever so slightly different profiles on the fronts v's the rears...
front(265/40R20) and rear(275/40R20)What is the exact size of your
front(265/??R??) and rear(275/??R??) tyres?
Was that across the axle?It’s not a great system. I’ve had it on my golf where two tyres went down and it didn’t pick it up because it was two at the same time. Must compare them against each other ¯\_(ツ)_/¯
Only 1.4% in overall diameter difference,front(265/40R20) and rear(275/40R20)
I did a test with a diffrent tyre profile on a rear axle of my Sharan 7N(PQ35).
Approximately every 20km my TPMS was indicating a fault and I had to reset it over and over.
I am pretty sure T6 MK100 is going to behave the same(happy to be proved wrong).
so I guess within system limits/tolerance.
That is how it works. It monitors wheel speed from the ABS sensors. If a difference between wheel speeds is detected, it presumes that is due to the tyre rolling radius changing, ie a deflating tyre, and activates the warning.I guess it logs each individual wheel rotation v speed and pings when one changes. We shall see, but hopefully not.
This was years ago on my mk5 but I’m sure it was diagonalfront(265/40R20) and rear(275/40R20)
What model year Golf?It’s not a great system. I’ve had it on my golf
Gti, mk5 2005What model year Golf?
