Weve metered out (with a clamp meter) about 18A of charging current coming into the Aux battery via the relay when the Aux battery is a lower SOC.
as the AUX battery charges . . . say on a long drive the SOC of the AUX battery increases, in proportion the current reduces.
so when both batteries are fully charged there is no current flow.
Current will only flow when there is a difference in potential (voltage), so when the AUX battery is low it will draw current from the starter battery and alternator when the engine is running.
Now on the flip side if the AUX battery is MORE charged than the starter battery say from solar etc then it has been seen the the AUX battery will BACK FEED current into the starter battery when the OEM BCM relay is engaged.
This has been witnessed by others on here with the Cally setup and the fancy panel on the roof that shows leisure battery setups etc. (was shown as -18A)
So in a Nutshell the BCM will do its thing to see that the starter battery is always at 80% SOC.
due to the nature in how the split charge relay joins the starter and Aux batteries together you would expect the AUX battery to also reach a 80% SOC.
@mmi done some nice readouts in the other thread. proving that his setup worked fine and kept both batteries at about 80% SOC.
in my case i think the EFB+ battery was a bit duff and squewing my early results.
So the general idea is to swap-out the factory relay for a DC-DC charger.
this will then allow the Aux battery to reach 100% SOC and NOT allow it to back-feed into the starter battery.
and the other preferred method is to fit solar charger to keep the leisure battery/ies topped up.
as for the voltage levels, i had multi meters connected up to the batteries similar to how
@mmi did....
when the BCM relay was connected i saw very similar voltage levels across both batteries.... (maybe 0.4v difference lower on the Aux battery due to cable volt drop)
both batteries showed the 15v regen spikes.
BUT only the starter battery showed the 9.6V drop when the motor was cranking in start stop mode, this was due to the relay isolating the AUX battery.
