Hi Joey
Have you had a look at Lees post?
Ignition Live Under Passenger Seat - How its done -
This question pops up fairly often so i thought i would look at it a bit closer. . . . .
If your van was factory fitted with the AUX battery under the seat, then your sorted. There is already a feed under there . . . . =]
BUT what if your van hasn't got the Factory option? . . . . Well there are two options for you.
Run (a new wire) the factory wire from the BCM under the dash/steering wheel
or
Run a (a new wire) from the ignition feed center-line of fuses in the under dash fuse panel...
or
- Dellmassive
- dellmassive fuse box sh how to guide ignition live solar
- Forum: Electrics, Lighting, ICE, Security
