I would like to hardware the dashcam front only at the mo, probably using my existing 402G. Considering the Thinkware 770 model or the 412G as an "upgrade".
Anyway, I understand that there are several options for fuse locations in a California. Under the control panel (thanks @Loz) although still not that happy screwing around there. Run the wire around windscreen. over the dash and down to under the passenger seat or fuses somewhere in the cab behind the drinks holder?
How do I access the fuses behind in the centre of the cab?
I'm trying to find which is the easiest for a novice. I'm not that confident with this kind of stuff so would appreciate some guidance. I have no trim tools so any suggestions for these would be greatly received too.
If it proves to much agro then I will find a local auto-electrician! Is there a dummies/idiots guide anywhere.
This is not my area of expertise so if you have nothing constructive to add would you mind keeping it to yourself
TIA
...message ends...
TIA
...message ends...
