One of the decisions I’ve yet to take on my conversion is whether or not to add a hot water capability plus shower attachment at the rear of the van. The option I’m considering is a Whale Expanse which uses gas to heat the water. Over £1k fitted so not to be taken lightly in terms of cost. The shower attachment is a couple of hundred quid.
Our van usage is going to be a mix of off-grid and campsites. For off grid I reckon 2 or 3 nights max over a weekend, for longer stays campsites are more likely. My current thinking (and that of my wife, I should add) is that we are not yet convinced on the value of this hot water investment. Our logic being that we‘ll be able to cope just fine without a shower for short periods of off grid camping, and on campsites hot showers should be available. Boiling a kettle on the hob for hot water should suffice. On the shower attachment itself, we may add this for the simple reason it may be handy to clean boots and the dog after a muddy walk. He can cope with a cold water shower.
Interested in hearing anyone’s insight or comments on our current logic and your opinion on the value of adding hot water to a conversion. Do you use it regularly? Is it worth it? Does it take up too much valuable space? Or does it just use too much gas? (We will have a Campingaz 907 cylinder which is currently set to only provide gas to the hob and bbq point). Are there recommended alternatives, for example I was looking at Colapz portable showers yesterday, which could be an option. Thanks.
